MountainMax
RE: Roller Rooster (ver1) help using offset red/yellow spring
Hey guys, It's been years since I had my secondary apart, but my belt is squeaking so I needed to add another shim, upon removal I took notice of my top hole for the spring and it was on 0 and i tried to take it apart slow enough to see what hole i had on the bottom when it flew apart, lol. It's been so long since I had it apart im not sure which of the lower holes I used. It's from Bender Racing and they recommended me to use (and sent it to me) the offset red/yellow spring and i did, but i forget what the lower hole should be in, can someone refresh my memory. I would call Bender but since it's under new management i doubt they could help me. What settings should I use? Thanks guys......
MountainMax
No-one, oh well, i went out and bought the yamaha silver spring so now I know i have a good place to start.
DARV
Life Member
what sled is on and how much you weight i have 3 of them i always us the silver and put in 3 & 3
MountainMax
It's on a 2002 MountainMax 144" 1.75 finger track and I weigh 250 pounds plus gear......
DARV
Life Member
start on 3 &3 if don't work go to 6&1 hope it works I love mine
MountainMax
im at 6 and 1 now, and she's fine, but I will go lower to see if it's still ok .
DARV
Life Member
I use silver spring 6&1 i I'm 300lbs
