RE: Roller Rooster (ver1) help using offset red/yellow spring
MountainMax
Churchill Falls,NL, Canada
Hey guys, It's been years since I had my secondary apart, but my belt is squeaking so I needed to add another shim, upon removal I took notice of my top hole for the spring and it was on 0 and i tried to take it apart slow enough to see what hole i had on the bottom when it flew apart, lol. It's been so long since I had it apart im not sure which of the lower holes I used. It's from Bender Racing and they recommended me to use (and sent it to me) the offset red/yellow spring and i did, but i forget what the lower hole should be in, can someone refresh my memory. I would call Bender but since it's under new management i doubt they could help me. What settings should I use? Thanks guys......
