700 SXr clutching
BBlueSRX
michigan
SLP triples and 1 layer removed from the head gasket. Max power with the SLP's is 8800. I was running 8cr's and 14.5 rollers with a Bender blue spring, and a Roller Rooster secondary, but my rollers went out and on the way home it ate 2 of the 8cr's. so... starting from scratch... should I stick with the 8cr's or do you guys have a better setup?? I can't remember what the rivets in the primary were but they were from SLP's clutching chart. 13.3 tip and 11.3 heel? I think? also I am running 1.25" predator with no studs. thanks
I have a set of 8dn-00's and 15.5 rollers from an SRX, would it even be worth the effort to try these??? If not what other weights should I look for?? the 8cr's seem pretty hard to come by.
The 8cr,s work well. i ran em with good results in my piped 700
found another set of 8cr's in the garage last night but they have chatter marks in them. any way of sanding these baby's back into shape? I have 1 good weight and 5 F'ed up ones
