SLP triples and 1 layer removed from the head gasket. Max power with the SLP's is 8800. I was running 8cr's and 14.5 rollers with a Bender blue spring, and a Roller Rooster secondary, but my rollers went out and on the way home it ate 2 of the 8cr's. so... starting from scratch... should I stick with the 8cr's or do you guys have a better setup?? I can't remember what the rivets in the primary were but they were from SLP's clutching chart. 13.3 tip and 11.3 heel? I think? also I am running 1.25" predator with no studs. thanks
