marty f
Took My Sled In(2000 Srx700)to Get Some Warranty Work Done On It,cracked W-arm,tach.. Had A New Powervavle Assm Put In Last Year And Since Then My Sled Did Not Have The Top End From Before So I Told Them About It When I Dropped It Off,well Yesterday I Went To The Dealer To See How It Was Going And They Showed Me That All Three Powervalves Were Snapped Off Where The Cable Attaches To The Valve!!!!!wow!!!!how Could This Of Happened The Valves Were Tottally Clean And Its A Brand New Servo Motor?the Guy At The Dealer Had Nothing To Say Other Than It Was Covered Under My Warranty.i Want To Know How It Happened For Future Reference!!!!what A Difference It Will Be Now When I Get New Ones,its Amazing How I Ran It With Them Broke And Did Not Even Know
yamaholic22
They had to have either been dirty at some point bad enough to cause them to rip through, or they were adjusted too tight and were pulled through when the valves contacted the top of the valve assembly.
SRX7
They may ( cables ) have been to tight.They have to have that 2.5 mm spec clearence. All mine pulled through and I had to repair them. Thats some warranty you have there for a sled that was built in 2000
how do I get an 8 year warrantee?????????
woolyviper
my 03 viper has warranty until january of 2009.BBlueSRX said:how do I get an 8 year warrantee?????????
its called YES
I would hazard a guess that the tech that originally put them in did not adjust the cables right and the service manager knew it. That is likely why he covered them. I am guessing that the dealership ate that cost.
lowellt
yes pun intended that is an amazing warranty!!!!!!!!!!!
marty f
I BOUGHT THE SLED FROM PORT YAMAHA IN 2005 WITH A TWO YEAR Y.E.S WARRANTY I WAS LUCKY TO GET IT BUT IT HAS PAID OFF ITSELF I BOUGHTIT FOR $400 AND WILL HAVE NOW AFTER 1 1/2 YEARS THE TOTAL WILL BE AFTER THERE ARE DONE THIS WEEK $1500 WORTH OF WORK EVEN MORE BECAUSE THEY HAVE NOT DIAGNOSED THE TACH YET TILL THEY FINISH THE POWERVALVES AND W-ARMSRX7 said:They may ( cables ) have been to tight.They have to have that 2.5 mm spec clearence. All mine pulled through and I had to repair them. Thats some warranty you have there for a sled that was built in 2000
