hauck growler can for 2002 srx
My buddy had one on his srx and then put the stock on it was alot faster with the stock silencer.It's about 4 legnths faster in a 1000ft and about 5mph differnce.
the pipes now sit a little higher now with the hauck can on there and the top most pipe is actually up against the inside hood protection (you know that black stuff) will this hurt, will it burn through? or should i try and lower it somehow?
with mine there is lil adjustment to wear you can move just a hair away from it. not sure with the old style growler though.
awww no way. well thanks for the input but that shouldnt happen b'cause it really makes no difference in my application how far the can protrudes through the belly its only changed by aprox 1/2 inch, thats all i needed, but thanks for your info...
hookedonblue
