Ron Boals
Getting my SRX ready for storage and noticed the tach performing erratically and then not at all, also noticed the lights were no longer working. I swapped out the tach with one from a 01 SXR 700 and the results were the same. ? is if the lighting coil in the stator responsible for the operation of the tach as well as the lights. I'll have to check, but assume the lighting coil is a replaceable part. Not sure my CDI is good, either. Someone on this website told me the newer ones were better than the 98, but I see the 01 and 02 SRX CDI's are different, is that correct? If it is not the lighting coil, can you point me where else to look? Thanks Ron
