Hill Climb help
EricMichael
Presque Isle, ME
Hey guys, i'm going to be racing my sled up a groomed mountain, maybe 800-1000 ft long. Its going to be side by side racing instead of cones. There are a few noles/hills in the way going up. I was wondering if you might know a good clutch set up or gears to run. I'm currently running 8dn-20's. This is going on saturday and i've already put the sled up but and going to try to set it up for this.Any help would be great. I have tomorrow to set it up. I have only two helix's. A 51/45 and a 51/43. I have 20/39 gears and 23/39. I have a hauck orange,gwg,ywy primarys with green secondary and silver.Also have 8ca's and stock 8ek weights. My current set up is 8dn-20's 3.1 or 3.6 inner and 4.5 outter. Also info on suspension would be helpful on ways to set that up.I'm guessing its ruffly 120 degrees or more.Thanks guys
well if it's up hill use your 20-39 gearing.I would run the 8ca weights they are a little better than the 8dn's for darg racing and the 51-43.
pro-116, I have the 8ca weights, the inner hole is empty and the outter has either .8 or 2.7 rivet. Can I just throw them in and use it like that or would it make THAT much diffrence to put proper weight?this is just a last season thing and i'm not looking to tune it perfect. THanks for your advice, it helps alot
Eric I wil be honest i haven't had much time on the vipers besides heel clickers.I have grass drag or raced just about every model but a viper.I know for a fact the 8ca weights will be faster.I think MrViper has a good 8ca set up for the viper I'm shure if you pm him he wouldn't mind helping you.Ryan
