oil leaking from air box??
mrviper700 said:
is it clean 2 stroke oil or is it black sooty oil?
From what i can see it appears to be sooty oil. it looks used. i actually thought i had a chain case leak when i first stuck my finger in it. then when i started looking the oil appeared up high(right under the air box) and appeared to be running from there down into the belly pan.
BETHEVIPER said:
what is your oiler set to?? if it is really rich on oil, it might be just spitback. should be 22mm stock up to 24 would be lean. sled should use about 1 quart every 150-200mls.
Honestly i have no idea what the oil pump is set at. the sled is in millinocket Maine and i am in boston. 5 hours away. I am thinking the pump might be out of spec and dumping too much oil into it.
As i said before i have barely used the sled this year. I have been relying on my friends that ride it to relay any info about the sleds operation back to me.
Obviously this plan isn't working.
I am pretty sure that I filled the oil tank before my last ride and i think the total miles i rode were about 60 miles. If i remember correct when i pulled the airbox last weekend i had aprox half a tank of oil left. seems like it is using a lot for 60 miles.
When i head back up to maine i will check the oil pump setting
Guys i really appreciate your input on this, It is very helpfull.
