Will Apex bars mount on an SRX?????
maxdlx said:
with the straight bars you loose about 2.5 inches of rise. if you only add a 2 inch it will actually be shorter. i have a 4.25 inch riser with bolts. $30plus shipping. Maxdlx
Will the cables still work? How high can you go before you need to run new?
thesledsurgeon said:
I put a set of nytro/apex bars on my Viper w/ a 5" rox riser and they work fantastic,if you are patient you can work the rt grip off the bar with a small pick or flat blade screw driver and then epoxy it back on..
just did this yesterday, drilled out the 2 rivets, insert small screwdriver, then twist it off, slide on throttle assembly.
my only problem now is how to fit all my stuff on my bars. the right side will be fine but on the left side i'm putting on a lefty throttle. Which moves my brake towards the center of the bars. now my handguard mount will be on the down curve of the bar, so it will not mount. plus I have to get a mtn. strap on there too...have to do some head scratching to figure this one out. Might have to figure out a way to modify the LH throttle to fit over my grip. Anyone have any suggestions.
