srxbonecrusher212
power valve cables adjusted properly but still falling of the servo motor,need help.
You got somthing not right,are they wraping around underneath?,can you post a good pic??
Like Daman says, something is not installed right, can you take a pic and post it . . .
SRX7
Do they look like this? are they connected to the power valve and not pulled out ?
I hope not 7,,thats the wrong way...LOLSRX7 said:Do they look like this? are they connected to the power valve and not pulled out ?
SRX7
No kidding thats what I discovered a few months back ( not my doing ) . Geee instant power when hooked up correctly.
Lol...
srxbonecrusher212
don't have digital camera to post pictures, but this doesn't happen all the time.You can go out for a drive on good trails then if you start to play in ther powder i will notice it will only be reving 8000 or so pop up the hood and the cabels are unhooked or wrapped arround the servo shive.
srxbonecrusher212
this is very frustrating had this happen all winter had 2 mechanics look at the power valves and both said it was adjusted properly.This was really the only problem i had with the machine all winter.I put on over 4000 km this season.The servo motor seems to be fine also, so could it be the cdi.
Does this happen EVERY time you ride the sled??
