Got the jackshaft bearing off the jackshaft with a puller for the SRX.Now how in hell is the best way to get the new bearing back on without recking it.It is a tight fit.
And what is the proper procedure to drain all the antifreeze from the engine and lines without making a mess everywhere.I siphoned the reservoir empty,took out the carbs and drained the 2 lines there.Do I have to lift the sled's back end and open the bleeder.Then somewhere under the exhaust manifolds there must be a drain,but antifreeze will spill out all the the bellypan and floor.Who's got the cleanest method to do this.
