Psi Pipes?
IMO these pipes like to run at too high a rev. The best pipes for these red top motors are Benders or SLPs. As for fitting with reverse, I'm not sure.
If you do go with these pipes, get your crank welded!
Reverse with SLP's is no problem even though their website says no. I had PSI's on an old RXL and loved them but have no experience with the Yammy pipes.
I have psi tripples on my 02 mm and they seemed to work very well. I run a 159 with MPI tunnel set up and a few other goodies with a little clutching they seemed to work good.
