SamuelJackson
Looking for vmax 600 94-96 pipe shootout results.
-sami
-sami
Dave_Vmax600
id be interested in this as well
INLINE4
- Jan 6, 2006
I do remember seeing Bender & RPC pipe dyno sheets..Both were almost exact..Dyno Tech has the results..I do have a set of GYT twins that work very well,but never seen any dyno sheets on them..I went by advice on going with them and not sorry for using them..
Dave_Vmax600
i wonder how my DG twins will perform
braindead1684
I have the GYT pipes as well and those pipes make the sled pull hard.
I know aguy that had gyt's also and it pulled very hard was really an improvement.I think MrSled has a set for sale.
mid 90's v-max's
I also can speak on the GYT twins. Have a set on my 96 xt and they work great on the tank. The stock 96 GYT single went on my 95 and showed a little improvment over the stock 94/95 pipe as well.
Dave_Vmax600
whats done to the engine?
INLINE4
- Jan 6, 2006
I do have a set Of GYT's for sale...They are on my 700 twin now..They work as that video shows(Lanzi's 2/25/07..you tube) They are brand new,only used this past season.Just raced,never trail ridden and always in a inclosed trailer..$200.00 if ya want them and what ever shipping would be..
Srxspec
Your #1 performance shop!
Stock Vmax 600: 96.4 hp @ 7750 & 65.8 ft lbs tq @ 7500
Aaen Single: 99.4 hp @ 7500 & 69.6 ft lbs tq @ 7500
Yamaha GYT Single: 97.9 hp @ 8000 & 66.2 ft lbs tq @ 7500
SLP Twins: 108.8 hp @ 7750 & 73.2 ft lbs tq @ 7750
PSI Twins: 107.1 hp @ 8250 & 68.6 ft lbs tq @ 8000
RPC Twins: 106.7 hp @ 8250 & 67.9 ft lbs tq @ 8250
Bender Twins: 108.3 @ 7750 & 73.4 ft lbs tq @ 7750
It should be noted that Dynotech also measured and compared the Bender & SLP twins and they came out with exact same pipe measurements and the results netted dang near the same HP & TQ readings.
Turbo Vmax 600 7 psi: 131.3 hp @ 7750 & 90.5 ft lbs tq @ 7500
Turbo Vmax 600 9 psi: 141.7 hp @ 7500 & 99.2 ft lbs tq @ 7500
Turbo Vmax 600 11 psi: 151.4 hp @ 7500 & 106.3 ft lbs tq @ 7250
Turbo Vmax 600 12.5 psi: 162.3 hp @ 7900 & 109.3 ft lbs tq @ 7700
Dave_Vmax600
WOW!
WOW!
Allen weren't the gyt twins made by bender?
mid 90's v-max's
pro116-
If not-they look almost identical......
braindead1684
By those numbers it would make sense that they are at least close to the Bender Pipes. Mine Pull hard to about 7500 Which would fit those specs pretty close. Anyone do any good clutching with those pipes?
mid 90's v-max's
Regarding the clutching etc for GYT twins, I believe I still have the paperwork at home. I will look tonight. The recomended new spring and helix. Also the head gasket mod works well with these pipes. We did all three and it made a BIG difference on the tank. This sled felt heavier than the v-max 4.
INLINE4
- Jan 6, 2006
My 700 BB racing...8BU's no rivets,Bender orange spring,4mm in shims,49/41 helix,Bender Viper secondary spring at 40' twist....For trail I would say 8CA's and 45/41 helix..
braindead1684
Thx Inline and mid 90's I will look into it for the next winter I don't mind the shocking pull when the pipes kick in but i know it would go a lot better and faster with the right setup, as right now it kicks in at 5700 and pull to 7500 35mph roughly to 75-80 the 35 is the part thats kinda bad on the trail
bufalobob
gyt pipes were made by power inc.
bob
bob
Thank's bob.I thought there where like two years that gyt's where made by bender than they switched to power inc?
bufalobob
pro:
power inc. made all the twin & triple gyt pipes.
bob
bob
