M-Max
anyone know if my 2001 MM 700 ski mounts and ski loops will direct
mount onto Apex Mountain ski bottoms.
Thanks for any suggestions.
terret725
most likely not. they are a different set up. they changed the skis in 2002 to the current style. other then the saddleless skis.
Does the MM have the thick cast aluminum mounts or the thin stamped ones? The thick cast mounts are taller than the stamped ones and will affect the ride height of the sled. The Saddleless ski's on the Apex are the same mount height as the thin stamped aluminum mount ski's. Is that clear as mud for you???
MtnMax600
The ski loops are different, and the apex skis dont need ski mounts, you just need the rubber and the longer hardware to bolt the apex skis to the MM.
MtnMax600 said:The ski loops are different, and the apex skis dont need ski mounts, you just need the rubber and the longer hardware to bolt the apex skis to the MM.
And ya, the loops are different too.
