yamaholic22
We can get you setup on clutching easy enough. As for belts be prepared, they aren't cheap (they went up a lot last year). OEM belt is really the only way to go, they are around $50-55 bucks a piece.
			YAMMIEGOD3:16
WITH ALL THIS SAID , GET RIGHT INTO POWER VALVES BEFORE YOU GO FURTHER. BY THE LOOKS OF THAT CLUTCH !! mmmm 3:16 (yammie tony)
			98srxPa
YAMMIEGOD3:16 said:WITH ALL THIS SAID , GET RIGHT INTO POWER VALVES BEFORE YOU GO FURTHER. BY THE LOOKS OF THAT CLUTCH !! mmmm 3:16 (yammie tony)
I pulled and cleaned the pv's everything looks good, no pulled cables.
I bought the sled for a grand , I am expecting to spend alittle to get it up to speed. The pervious owner wore the belt down so low I wasnt susprised it broke. He threw on a napa gates xtreme 38X4420 belt
							shortstop20
 - Mar 6, 2005
 - Stickney, South Dakota
 - www.snowmobilefanatics.net
yamaholic22 said:they are around $50-55 bucks a piece.
WOW, I remember buying them for $30-$40 when I had my SRX.
cacsrx1
That was for your Exciter.shortstop20 said:WOW, I remember buying them for $30-$40 when I had my SRX.
kingtigg
Dont forget to ensure all THREE cylinders are firing well!
(I got caught on this one while fixing up my SRX...didnt realize the center cyl was running well even tho the spark was fine!...ended up changing the plugs and all was well!)
98srxPa
kingtigg said:Dont forget to ensure all THREE cylinders are firing well!
That was the first thing i did changed all three plugs and made sure the contacts were clean
