maxwell
What is the ballpark number for an SRX with stock compression?
ball park 135-140 I believe
YAMMIEGOD3:16
I SEEN A HAIR LOWER THAN RYAN,S # s !!!!!! 3:16 (yammie tony)
yamaholic22
I usually see 130 psi or so with good rings on my gauge on the 00-02.
YAMMIEGOD3:16
YEP MIKE!!!!!!! 3:16 (yammie tony)
My other compression guage show's lower also.A lot depends on the guage.Usally guages where the needle sticks out further on the end read slightly higher.
yes Ryan, it all depends on the brand of the compression guage and more importantly the threaded adaptor being used in place of the spark plug, to get close to accurate, you need the long 14mm threaded adaptor that takes up the same volume when installed as the spark plug.
Its also more important then just a number, that all 3 are say within 10% of each other, as long as your guage reads 110lbs or better in all 3 no matter what length your thread adapter is your in pretty good shape engine wise.
This isnt to be confused with a leak down test that actually test the actual sealing ability of the rings, thats another thread all in it self.
nailsandrails
FYI - My old 99 SRX was 125 on all three when new from the dealer. Can't comment on the guage they used. Just caught it on the receipt from the previous owner.
srx6
- Jun 29, 2003
My 99 srx 600 stock was 121psi with 14mm adapter.
seca
my 99 srx 700 is 120lbs each cyl. with my crappy canadian tire gauge.
marty f
under$40
anything under $40 for a comp gauge will show around 120psi
98-99 has a bit lower compression from a larger dome in the head and larger squish clearance then the 00-02 srx does, so they will show slightly less compression.
