Yamaouch08
How tall of a Rox pivot riser can I put on my 02 Viper and still use stock cables? I have a 2 inch powermadd riser block on now with stock cables,but want to get a pivot riser to move the bars forward so I can stand up and ride easier. Here is the link to the risers on the Rox website:
http://www.roxspeedfx.com/cgi-bin/cart/showitems.cgi?subcat_id=278
3.5 inches at least will work. maxdlx
richierich
yep 3.5 ".if you need one let me know.thanks
Yamaouch08
How much are they shipped? I just need the riser and thats it right? I have the stock handlebars.richierich said:yep 3.5 ".if you need one let me know.thanks
richierich
$88 shipped.thats all you need.you can order online or call me with order.thanks
http://www.richmotorsports.com/store/view_product.php?product=ROXK777Q87
I'm curious... how does the pivot riser actually work? Is it 'on the fly' adjustable or does it require a rachet? I currently have a 2" riser on my viper and I'm considering going up to 3" and the pivot concept seems to be the way to go if it works how I think it does.
Rox makes two different kind of pivot risers. The basic one you have to loosen the bolts in the handle bar clamps to adjust it. Then they have a pivot rise that you can adjust the height by loosening cap screws on the riser to adjust it.
I have seen a pivot riser in the magazines that has wing bolts that you could adjust with out any tools. However I remember it being something like $300. G.B.
richierich
most pivot risers are your basic 2 pivot points top and bottom.you cant adjust on the fly.you set the riser in the position you like and thats where it stays.they do offer a height adjustable one so you can go from 4"-5.5" but they are more money and are not adjustable while riding.any questions let me know.
Yamaouch08
I got the 3.5 Rox pivot riser from Rich and it looks like it will work prety good,put me at a better position especially with my Excell seat riser,more rider forward.
...so the 3.5 pivot riser easily adjusts for different angles for a more or less forward riding position? I'm not looking to be able to adjust the height of the bars. I would like to be able to pivot it for a stand-up riding position and sit down position... is this possible with the ROX pivot riser?
richierich
yes exactly.
SRX RIDER
Yamaouch08 said:I got the 3.5 Rox pivot riser from Rich and it looks like it will work prety good,put me at a better position especially with my Excell seat riser,more rider forward.
Here's what you'll get. If you like your Viper with stock ergos, you'll love it with the Rox/Excell combo.
I think the 3.5" would be perfect although I don't think I would have managed to squeeze that one on my Viper. 2" was pretty tight especially with the electrical wires alone. The wife's S will be set up this way by the end of the week. I'm not even giving here the option of riding without the risrs. It makes THAT MUCH difference.
Yamaouch08
That almost looks like my setup,except for I have the 3.5 pivot riser. You just have to reroute everything to make the 3.5 fit. The pivot riser and seat riser make it a totally different machine(for the better!!) Perfect ergos with this setupSRX RIDER said:Here's what you'll get. If you like your Viper with stock ergos, you'll love it with the Rox/Excell combo.
yammiman
What would be a good or maximum height with a standard handle bar riser on an SRX? - non pivot
yammiman
Anyone?
kgwmu
I was told a 2" riser is the tallest you can go on an SRX.
davessrx
I asked this question awhile back and never got anywhere......doesn't anyone have a riser on a srx????
yammiman
....I was told a 2" riser is the tallest you can go on an SRX....
I think you are right - thanks!
richierich
2" is max without changing cables.
yammiman
Cool! - Thanks Guys!!
