Can anyone tell me what is involved with converting the stock Viper rear control rods to hand adjust capability? I was thinking of buying the Yamaha accessory hand adjust nuts and I was wondering if you had to remove the control rods or can you add the nuts without totally removing the rods?
Thanks, G.B.
Thanks, G.B.
you just take the 2 nuts off the rod, and screw the hand adjust ones on. Its just that simple. You only need to remove the bolt in the bottom of the rod and the bolt through the rail to do it. Maxdlx
viper48
Like maxdlx said......It's nothing major to do....I think mine took 30mins. if that?
Thanks maxdlx and viper48! I was thinking that it shouldnt be too complicated. I just could not find any posts on this topic or info on taking apart the stock control rods in any of the Yamaha shop manuals. Thanks again, G.B.
