KYB specs
rancidjo
Southern Manitoba, Canada
I found the piston depth and gas pressure specs (In the tech. section) for my viper shocks but can not find how much oil to put in them for a rebuild.
Does someone know how much oil to put in the shocks??
What I found in the tech section was:
Center shock: piston depth 120mm .....284psi
rear shock: piston depth 186mm.....284psi
