clutch setup
marty f
WATERTOWN,MN
whats the best way to set up my clutch so i get better acceleration and more top end i have a stock srx and i weigh 210lbs
Congrats; u just won the contest for the 1 millionth guy to ask this exact question! Search sRX clutching & you should be done reading in about 2 months.
good or not
The 8DN-20's with a green spring and 4.5 g's in both holes and a 48/40 advant-edge will definately give a noticeable improvement in acceleration, as well as top end whether you like it or not, lol.
__________________
is this a good setup for an 2000 srx stock
are the 8dn-20's stock already
8dn20's are stock in your 00, you will need 3-4.5g rivets to change out the inners from the stock 3.6g. That set-up is one that is used requently on this board yes.
