v3's ?
there is a special tool needed to change the pedals, it simply slides down between the pedals and the cage, which pops off the cage allowing the 2 outside reeds to be removed, the inside reeds have 2 little slides that go in the side at the bottom of the reeds in the middle which need to be removed with a small screwdriver or something that size by pushing one of the slides from one side, then doing the same with the other slide from the inside.
Argh....I can only find 4 right now. I know I have a bag with about 20 kicking around. I'll try to track it down. How does $30 sound for 4?
Sell the V3's and try and find a set of 2's. The V-force 3's with the plastic cages don't seal as well as the V-force 2's. Or, if you want an awesome set of reeds, get the Boysen Rad Valves. They are awesome! Just my opinion,
