x2ryder
I used to use Pennzoil snowmobile oil in my ZR's ZRT's & T-CAT'S with zero problems. I now have a SRX and was thinking of using it again. But I was wondering how it would do with my powervalves? Anyone use this oil with powervalves?
I wouldn't use it, stick with somthing you know that works and memebers
on here have used, i love using Amsoil's interceptor,i use it in all my sleds
PV's or not,there's aslo KLOTZ, bluemarble and some others that the members can vouch for that keep PV's clean..
700sx
x2ryder said:I used to use Pennzoil snowmobile oil in my ZR's ZRT's & T-CAT'S with zero problems. I now have a SRX and was thinking of using it again. But I was wondering how it would do with my powervalves? Anyone use this oil with powervalves?
I use Penn in all my sleds and never had a problem 8756mi on one of my 700's and never had to touch the motor. knock on wood!!
x2ryder
I think I am going to give it a try. I have never had a oil related failure on a sled. Besides it's 11.79 a gallon. Have used both Yamalube and amsoil intercepter in my SRX in the past and the valves looked the same using both. I think if I ran it with zero probelms in a 1004 ported T-Cat with a set of 190 psi heads and triple D&D pipes on it in the grass and on the lake it will be fine in a SRX.
My PV's on interceptor have been clean, good luck with the Pennz..
Amsoil is a full synthetic oil also,very good for your motor is the Pennz?
Pennzoil is an ASH based oil ( from what i can remember) and ash based oils didnt hold up really well when it was REALLY COLD outside!!! (look at ME trying to start something
No not you,nosboy said:Pennzoil is an ASH based oil ( from what i can remember) and ash based oils didnt hold up really well when it was REALLY COLD outside!!! (look at ME trying to start something![]()
nothing wrong with factssnoprokidf6
my dad uses it in the viper, 7356 miles and no problems
How are the PV's?, clean?snoprokidf6 said:my dad uses it in the viper, 7356 miles and no problems
snoprokidf6
decent, but they need a cleaning
