anyone know the horsepower rating for a 1984 phazer 488 fan.
maybe 60, i have an 86 pz, it's lite and snappy, feels like big power in that chassis..
53hp if my memory has not failed me?
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
65 HP seems to ring a bell for me?
YAMMIEGOD3:16
WHAT THE HELL. WHILE EVERYBODY THROWING NUMBERS OUT I THINK THEY WERE 68-72 AREA. VERY LITE !! THEY WERE NEAT SLED. 3:16 (yammie tony)
Classic SRX
63 was the number I always heard.
Edit: DynoTech Vol2 Num2 - PZ pipe shootout - 63hp @ 6750RPM - stock pipe, stock Y-pipe, polished ports, SX (modified skirt) pistons, gutted airbox, stock carbs (150 MJ), 100 octane fuel. Note: with identical setup, but Aaen quiet can pipe - 81hp @ 7500RPM
So the number in my head wasn't for a truely stock motor.
A.
A.
YAMMIEGOD3:16
ANGUS, I DUG MY *** OFF FOR YOU ON THAT EXCITER CLUTCHING INFO. NO LUCK !!!!! I DO REMEMBER FRIEND OF MINE (94 max) BOUGHT A CLUTCH SETUP FROM HAUCK FOR HIS THAT WORKED GREAT. 3:16 (yammie tony)
Classic SRX
Thanks for trying Tony. You see the latest on my clutching situation? Any advice?
A.
A.
Triple X
rich is right!
Vmax540
rich said:Phazers were 56 hp.
They were held to 56hp in the 1980's to fit into that Snocross/crosscountry (?) raceing class.
B.T.W. Phazer's are 485cc and the Polaris fan's were 488cc
I rounded up!! it's different with so many things, clutching,gearing,air temp,etc,etc.
opsled
Vmax540 said:They were held to 56hp in the 1980's to fit into that Snocross/crosscountry (?) raceing class.
Dotto!!! Vmax540 is right.
They were originally a 56hp "piped" engine that was detuned with the pipe to be able to run in stock 56hp crosscountry racing. Adding a pipe can give the Phazer 10 to 15hp with no other mods (other than jetting). It is not that hard to get close to 80 hp out of a 485cc Phazer and still have a very trailable sled. More is available but you are looking at something that is not very trail friendly.
opsled
Thats the truth Phil!!!, a phazer with a pipe and a bender cold air kit would run great, lots of power, reliable. As soon as you ported the cylinders and reeds(really adding airflow) the stock butterfly carbs would destroy the engine every time in the mid range, no matter what, I drilled out the passages in the carbs, used 110 pilot jets, nothing would prevent the mid range slow burndown. Its the way the carbs are designed to pull fuel.(or lack of!!)
We eventually used a set of exciter slide carbs and the sled woke up even more power and we never replaced another piston in it again, they actually can be quite powerfull little motors when done up, but if you mod one, just change the carbs or youll drive yourself broke and nuts all at the same time....LOL!!! ahh the good ol days of the phazers............
BornYamaha
First Few Years 84-89 Yamaha said 53 HP,56 HP with SX Pistons was the upgrade for 56HP class. Intake side of piston opened up. "90" Thru whenever they lost the struts Phazer II Yamaha rated at 58 HP. I think the newer ones after struts had 62 or 63. As a by the way, while I'm thinking of it, if anyone here happens to currently own Donahue's winning Eagle River snowcross machine ,("85" I think), I have the front sway bar in my garage. I owned it for a couple years in the late "80s". I Just forgot about it when I sold it. The current owner can have it.
Dave_Vmax600
i need to find an aaen single pipe for my phazer. i have the bender cold air kit right now.
love my Phazer, It's a HOOT to watch everybody whine when they fuel up or get there big pigs stuck!!!! See yaaaa, I'll keep ride'N!!!!!!!!!!!!!!
Vmax540
Please give me jetting advise Mrviper, Opsled or anyone else who has tinkered with the Phazer. My cousin put together a 1995 Mountain lite this summer and after reading this post we're a little nervous about the mid range. Below is a list of the mods.
-Sx pistons
-Boyesen reeds
-Bender cold air and exhaust kits
-gutted airbox
-Aaen Quiet Can with stock Y pipe
-Stock carbs with 150 M.J. AND 110 Pilot's
-Stock heads/gasket
-Lightly smoothed the exhaust and tranfer ports
-1200' elevation
-Sx pistons
-Boyesen reeds
-gutted airbox
-Stock heads/gasket
-1200' elevation
Vmax540
Some before and after pictures.
-06 Nitro bars
-07 Phazer handle bar pad
-Handle bar riser
-Exciter Pod and gauges
-Rear suspension dropped 1.5"
-Aluminum cross shafts in rear suspension
-Lightweight 8" rear idler's
-Tunnel supports
-Vmax 5/600 T.S.S. Struts
-USI Skies
-Riechards torque arm
-Bender cold air intake and hot air exhaust kits
-Belly pan skid plate
-1984 Phazer seat chopped and 4" of foam added to the top
-Widened to 40" ski stance
-Waiting on paint/decals and maybe a exhaust temp gauge.
-06 Nitro bars
-Handle bar riser
-Tunnel supports
-USI Skies
YAMAHABUNCH
A Stock Phazer Was Rated By Yamaha At 51.8 The Pro Stock Kit Was 56 Hp Which Consisted Of Phazer Sx Pistons And Removal Of The Ring In The Head Pipe Of The Exhaust
