I have two srx bottom ends they both have rods were the top end measures 23mm I.D. There is no markings on the rods and dont know what year they are. I measured a 838 rod out of a GPX and it is 22mm I.D which uses a 18mm pin and the newer rod measures 25mm I.D and uses a 20mm pin.
My question: Did yamaha ever use different roller bearings for the 18mm pin?
Did any other yamaha cranks fit in a srx case that would used rods like this?
Any help or info
Any help or info
