Yamahasrx700
What is the tallest lug track WITH studs can I run in a 2002 SRX with an RX1 rear skid.
mrviper700
VIP Lifetime Member
1.25" is the max, some have run it with the tunnel and heat exchanger protectors still.
Better off to run a 1" with studs, you wont have to keep the track tight like a banjo string to keep it from ballooning up at speed and rubbing the protectors as easy and it will roll alot easier with a looser track.
Yamahasrx700
