Yamahasrx700
What is the tallest lug track WITH studs can I run in a 2002 SRX with an RX1 rear skid.
1.25" is the max, some have run it with the tunnel and heat exchanger protectors still.
Better off to run a 1" with studs, you wont have to keep the track tight like a banjo string to keep it from ballooning up at speed and rubbing the protectors as easy and it will roll alot easier with a looser track.
Yamahasrx700
