98srxrider
I have a 98 srx with heelclicker clutch arms. I have a 51-37 helix to try, what secondary spring do I need? I am thinking the green but am not sure. I currently have a silver and red if one of those will work.
nailsandrails
You will get different responses, but Green is the most popular on this board. Do a search on SRX Heelclickers and you can read for days!!
Red at 80* or 90* should be OK for trail. Drop it to 60* if you are doing radar runs.
You could also use the green at 60* or 70* for trail, 40* or 50* for bare ice racing.
Either of the above should get you close. If you're loosing RPM on top +2000', tighten the spring 10*.
98srxrider
thanks guys, i will start with the red one
If you don't have a green one I can send you one (used) to try before you buy the new one..Nick
Just re-read you post again and it sounds like you've got a red, but would have to buy a green.
Use the RED as specified above. If you need it tighter then 90* to stop the RPMs from dropping switch to a green @ 70*.
YAMMIEGOD3:16
GREEN, START AT 2-6 @ 80 DEGREE, 3:16 (yammie tony)
I like the green my self.If your doing speed runs the red works good.
