RX-1 clutch compenets in srx?
Fro
Howell, Mi
Scored a rx-1 helix off ebay. I was going to use it with a green secondary, 8dn20's & www primary. It was a package sale, so I have the stock weights & both stock springs. Are the weights or springs an option to use or should I stick with the original plan? If they won't work, they are for sale or trade.
BTW...2003 rx-1 into '99 srx.
Thanks, Fro.
Stock rx-1 weights are 76 grams. The 8dn-20,s are 50 something grams loaded up. So; nope; they won,t work & the primary spring does not have enuff preload for proper engagement.
If anyone wants them for sale or trade pm me.
you can not use rx1 weights in a non four stroke clutch. the weights are really flat and when they swing out they will hit the inside of the spider. the four strokes have a spider that has a section missing from it(rectangular hole) so the weights will swing through.
it is hard to beat that 8dn 20 setup in a srx, there is a reason it has been done to death.
