SRXfromHELL
I noticed that the windows in my piston skirt are 1/8 to 3/16 smaller than the ports in the cylinders should I cut this away and match it to the port ? It's bored and sleeved to 68.5 mm using 78-80srx pistons
mrviper700 said:hmm, the early srx is a 59.6mm stroke and the 81srx is a 64mm stroke, does the piston have the same compression height? if not they wont come all the way up to TDC or will come up too far?? maybe they are the same distance from the wristpin to the top o the piston edge??
SRXfromHELL said:I have the top end off the sled with the jugs still attached to the head when I place the pistons in the jugs resting against the head the exhaust port is covered but not by very much (1/8 inch) . given the fact that they are above TDC and the thichness of the base gasket will raise the jugs slightly . is that enough or should I consider thicker base gasket and how would that effect performance
anyone have a 81 piston laying around they could measure for me ? total length and bottom of pin to bottom of skirt
Kevin
