what is the tollerance for srx piston wear before to replace them ?? can find the old thread about it ...
I saw your pics. You probably need to rehone your cylinder(s) With the crosshatching gone the cylinders get glazed & the rings can,t seal properly. It doesn,t look like a piston clearence issue to me.
piston size standard is 68.944 to 68.947 mm (2.7143- 2.7144 in)modsrx said:what is the tollerance for srx piston wear before to replace them ?? can find the old thread about it ...
so anything under 68.944 is under spec. they don't allow much..
