1.5" track
maximus070301
Minnesota
I just put in a new ad bovinzx2 136" on a 02 viper this weekend i used a 1.5" intense track with 8" drivers,the only problem is that the track rubs a little on the protection bars of the front heat exchanger,can these bars be cut off or does anyone have another suggestion.Or can i just let the track were down a little?
Mine are cut off on my SRX with 9 tooth drivers and 1.25 track. I didn't install it and it has been ok so far.....about 2k miles.
yes you can easily remove the coolant protectors. it makes for alot more clearance. dont even need 8 tooth drivers with them removed. your all set to clear 1.75" with them removed. just dont remove them if studs are a plan.
