Vector88
i got my heel clicker kit today for my 03 rx1 mountain and it says i have to put 3.3 grams in the shoulder of the heelclicker weights and also 3.3 grams on the tip. i didnt get 3.3 grams right on with a digital scale at home, i got 3.4 grams with just the bolt that goes in the tip of the weight and i got 3.5 grams for the shoulder. i had to add 3 washers on this for the shoulder to get 3.5 grams. so would it be alright to just put these on? would it hurt anything if i run it like this? this is the closes i can get to 3.3 grams. please help me. this is my first time installing a clutch kit! also, i weighed all 3 weights and it is 56.1, 56.4, and 56.5 grams. would this be good or i will need to make it all the same? i weighed each bolt too that is suppost to be 3.3 grams, they are all 3.4 now and they are all the same weight but not 3.3 grams. let me know what to do!
			Vector88
no help?
			it will be pretty close, try it and see what rpm your at.
			Vector88
found out i have to have 5 mm rollers and i currently have 6.5 mm on my rx1 mountain.
