Yama49601
mopar1rules said:What did your friend have to have hauck check out on the cylinders/pistons? Was there some scoring? What is this updated piston talk? I don't know anything about this. The clutch tuning per turk's specs, is this setup the one that's in the technical section? Do you know your buddies exact clutch setup now...weights, helix, spring? Right now our dad's sled has a ripsaw track on it....so the good track thing is taken care of. Would he (my bro) be better off buying a hauck clutch kit, or setting it up per turks setup? Thanks guys for all this great info coming in!![]()
He just wanted to have them look at the stuff because he's paranoid
But if it was me I'd go with Turks setup for the clutch. I'd have to check to make sure what exactly it is again but I think it's 8ab weights and a 50/44 helix. There were 2 setups Turk had posted for that each using different weights I think. But I'm almost positive that's what my friend used. Is that the one you saw or no? I'll call him in a few minutes and ask him. I had all of that saved in my PM inbox but it's gone...Yama49601
Ok I found it. This is the setup he's using:
Originally Posted by Turk
8ab weights; 50/44 helix, green secondary spring at 60 wrap. Clutch it to run at 7800 rpm. I think if I remember that far back 2.4 gram rivets in both holes was close.
Also:
50/44 dalton; micro belmont; hauck cut of helix is fine.
My friend got the Micro Belmont helix.
Also:
Dave_Vmax600
single pipes are nice too.
i had an AAEN
6-7hp gains, awesome bottom end and amazing sound
i had an AAEN
srv540
why would yamaha even make the gyt pipes for the 500/600? I hear they were great on the earlier vmax's
braindead1684
I have the GYTs on my 96 xt and it PULLs hard when they are in their range no real problems just really picky when setting up the first time i hear (came on the sled tuned so i got lucky)
mopar1rules
here's what turk pm'ed to me:
8ca weights, 50/44 helix, 2.4g in each hole, make sure it runs at 7800
turk never told me how much wrap. so its 60 deg? that would be holes 3-3..correct? which weights should I use....the 8ca or 8ab?
he also never told me what secondary spring. so i should use the green spring?
..mopar1rules said:so its 60 deg? that would be holes 3-3..correct?
Yama49601
mopar1rules said:here's what turk pm'ed to me:
When did he send you that information? That was the setup he recommended originally then changed it to what I posted. Or at least the post using the 8ca weights is a lot older than the one recommending the 8ab's...
You can see the posts here:
8ca's his post is number 6
And here's the post about using the 8ab's:
here
moss
Yama49601 said:When did he send you that information? That was the setup he recommended originally then changed it to what I posted. Or at least the post using the 8ca weights is a lot older than the one recommending the 8ab's...
here
Where can you get the new weights? Dealer? Which sled had them stock?
Anything else thats needed? Where would I get a 50/44 helix?
fleet man
I'm running GYT twins and they made a hell of a performance difference. I'm still a bit on the fat side but hopefully I'll get some tuning time in the very near future. Supposed to snow sat and Sunday.
Yama49601
moss said:Where can you get the new weights? Dealer? Which sled had them stock?
You can either get the weights from the dealer or try to find some used ones on here in the classifieds section. Look around on Google or ebay for a Micro Belmont, Dalton or Hauck helix. Or even on here. The ones from Micro Belmont are really nice looking, when my friend got his I ordered it for him and I think it was around $100 new (shipped). They're located in Grand Rapids Michigan. Here's their number if you need it:
MICRO BELMONT, INC.
5390 Clay Avenue Southwest
Grand Rapids, MI, 49548 USA
Phone: 616-534-9681
Fax: 616-532-2275
Don't forget to get the new rivets...
Here's the chart showing what weights came on what...
