98 srx!
vintage srx
harrow ontario
Working on a98 srx would there be any harm removing the dividers in the air box,with stock jetting.Is the preload on the secondary 60 degrees.
If you remove any dividers in the air box you have to rejet, I removed the vertical dividers only in my '98 600 and had to go up 1 main jet size I beleive. As for the secondary I'm not sure off the top pf my head, 60 sounds right though
