yamahaulinass
what daman that not adjustuable?? what do i do then?
that adjustment is for a stock OEM secondary, is your secondary OEM?yamahaulinass said:what daman that not adjustuable?? what do i do then?
where is hauk(sp?) stamped on it?
yamahaulinass
when u get on ur knees and look at it its stamped on the outside..... by the whaty is the stock seting 4 them 3 front air screws on the srx?? the ones that on the outside of the carb??
if ya get board post a pic of your seconday....yamahaulinass said:when u get on ur knees and look at it its stamped on the outside.....
are you talking the fuel(pilot screws)screws under the carb?? 1-1/8 isyamahaulinass said:by the whaty is the stock seting 4 them 3 front air screws on the srx?? the ones that on the outside of the carb?
spec...
yamahaulinass
ok it squeling in the primary daman?
change_up
I think he's just got a hauck helix. Take the secondary off, look on the back side and if your clutch is OEM Yamaha (helix doesn't matter) you can take out 1 washer on all three bolts to loosen up the secondary a bit.
thats what i'm thinking too, but dunnochange_up said:I think he's just got a hauck helix.
yamahaulinass
well i got my pv cleaned and everthing looks good my belt quit squeeling? when you adjust ur tran rods to pull the skis doe it put that wieghr on the front of the skid cause my back of the track is almost off the grouond?
It's hard to under stand what you wrote, anyway did you do anything to
your front limiter straps??
lilracer
not to steal anyone's post but i tightened up my front limiter starps. The back of my track was way off the ground as well. My question is, how tight should you go with the front straps?
yamahaulinass
my straps are still loose y? my question was should the back of the track b off the ground when u adjust your transfer rods down?
RIVERRUNNER
Yamhahaulin and Lil racer, all of that depends on several things on your rear suspension.....where are your shocks set at??? But, I have my limiterstraps set at 10mm which is the minimum amount that yamaha stays you should have them at and I have my transfer rods all the way loose and my tracks is level. Have you guys ever read any of BETHEVIPER'S posts? Check them out they are in the tech faq forum and it is really informative on what you are going to want to do to set up your sleds suspension. This one is setting up your suspension.
http://www.totallyamaha.net/forums/showthread.php?t=34503
Also if you start a new thread you will get more responses on your questions, because more people can find them both now and later when the search...
Hope this helps......Good luck guys!!!!
lilracer
Thanks, i appreciate the response !
^Right, good info RR, thanks..RIVERRUNNER said:Yamhahaulin and Lil racer, all of that depends on several things on your rear suspension.....where are your shocks set at??? But, I have my limiterstraps set at 10mm which is the minimum amount that yamaha stays you should have them at and I have my transfer rods all the way loose and my tracks is level. Have you guys ever read any of BETHEVIPER'S posts? Check them out they are in the tech faq forum and it is really informative on what you are going to want to do to set up your sleds suspension. This one is setting up your suspension.
