u had more luck than me lollll... i was not on safe side at all i burn 3 or 4 piston before getting up to 160 main and run run run without problem not always easy to see
Triple X
Every engine is different, that is why you check, check and check again. My motor has over 20K, original pistons, thrid set of rings.
modsrx said:u had more luck than me lollll... i was not on safe side at all i burn 3 or 4 piston before getting up to 160 main and run run run without problem not always easy to see
What do you have done?
not mutch shaved heads and ported and some done to piston ... and then piston melt but seem to work good with 160 accross...
That's it porting? Man I was running 152.5 and 42.5 clip #3 accros the board. I was SUPER rich with my porting!!!!! When I say porting, I mean porting! I have my specs way beyond the 2001 specs.
