I need to replace the plastic bushings top and bottom on the center shock. I looked up the part numbers and they show a Collar and Bush-Sold for #21? Which part number is it?
21. 90387-145G7-00 COLLAR 8EK3 4
21. 90381-14101-00 BUSH, SOLID 8EN1 4
Plus, the metal collar is a little rusted, can I sand it clean or should I just replace?
22. 90387-105G5-00 COLLAR
It's not the collar, it's the bushing/solid, just clean up the collar
Gone Blue
800 said:It's not the collar, it's the bushing/solid, just clean up the collar
I just sanded mine and greased them up.
G.B.
Thanks GB. I will do the same. I need to order 4 #90381-14101-00 Bush,SOLD for the front skid shock.
BETHEVIPER
Life Member
read through my skid article below, it tells how to fix it once, it will last forever and let your shock work properly
