I need to replace the plastic bushings top and bottom on the center shock. I looked up the part numbers and they show a Collar and Bush-Sold for #21? Which part number is it?
21. 90387-145G7-00 COLLAR 8EK3 4
21. 90381-14101-00 BUSH, SOLID 8EN1 4
Plus, the metal collar is a little rusted, can I sand it clean or should I just replace?
22. 90387-105G5-00 COLLAR
It's not the collar, it's the bushing/solid, just clean up the collar
800 said:It's not the collar, it's the bushing/solid, just clean up the collar
I just sanded mine and greased them up.
G.B.
Thanks GB. I will do the same. I need to order 4 #90381-14101-00 Bush,SOLD for the front skid shock.
read through my skid article below, it tells how to fix it once, it will last forever and let your shock work properly
