Simple question :
How many washers can I use under the 3 adjustment screws in general? I know about the belt wear limit but just wondering.
Thanks,
Thanks,
I really don't know if there is any amount, just make sure that your C.C. is on & that the belt is not warn past its service life...if your only doing this to extend belt life, if the belt is still within it specs...ok...then thats not really a great way to go about it if its worn...If the next time your at your dealer ask he/her to get 5-6 belts for you, will see that maybe only 2 belts may be the same...you will also see that the more you screw in & out them screws that you damage the ring or the screws mushrooms...not to mention that its a pain to do on the trail side ...cheers
How ever many you need,your bolt is only so long.
Oh and i gota ask, it doesn't look good the 'ol pz and clearing that ditch jump in your Avy.....lol
It's not a ditch, it's a fenceline!
And it did clear without touching the fence or shrubs...
The "jump area" was pretty short and steep so it kicked the nose a bit too high.
LOL.....ok, looks killer dude, the 'ol PZ launch'en..
