YAMMIEGOD3:16
SOUNDS RIGHT JOSH. 3:16 (yammie tony)
Are the rivets available from the dealer too? or do I need to order them somewhere else?
Looking to clutch a friends 99 SRX 600 with this set-up.
regert
I am also wondering where I can get some rivets for the weights?????
marty f
Here You Go, Awsome Setup For Your Srx!!!
Advantedge 48/40 Helix
Green Secondary Spring Wrapped At 60
4.5 Gram Weights
4.5 Gram Weights
marty f
Dealer Has Rivets!
Dealer Has Rivets!and The Spring
SRX Cream Machine
- Oct 28, 2004
hey Marty , are you talking about for my 1999 SRX 600???
Thats who Moab11 was asking for?
marty f
sorry 700
i am talking about a 700
SRX Cream Machine
- Oct 28, 2004
got any good combinations for a 99 SRX??? And has either of you guys heard anything good or bad about the Goodwin Performance clutch kits for the SRX's???
600 srx
8bu-00 weights with inner empty & 2.4 rivet in tip
45/39 helix
Silver secondary spring at 60 wrap
45/39 helix
SRX Cream Machine
- Oct 28, 2004
Thanks Turk for the info, you don't have to do anything with the primary spring??? what kind of engagement should I be getting or other performance gains???
Stock primary spring plus 2-3 engagement shims will give you about 4200 engagement.
1slo_MM
Mr Viper, is the set up you gave on page one with stock gearing or..?
Anyone, also looking for a set up (clutches and gears) for 7000' ^^^ on a 01 srx 136 1.5
any help would be great!!
-dru
-dru
