extroverts which is best?
motodave289
N.E. Indiana
Need 8 tooth for srx. Who makes best ones. Was thinking about wahl bros. but looking for some input. Anybody know if mountain max used 8 tooth extroverts. Wahl bros. says you can run just middle 2 sprockets. Any problems with this?
Wahl's are fine unless your into turbo power. To my knowledge Yamaha has never put extros on a stock sled. Yep you can just run the two middle ones.
ski doo's have been highly spoken about, but i don't know if they come in 8 tooth. someone just posted about them too, and how the runout on them was almost non-existent, and that wahl's runout was terrible
Apex mtn comes with them stock, Best are the Avid drivers, then your choice on the ski-doo ones and Wahl,and Mpi. I am 99% sure Wahl and Mpi are both made by ppd (cdn wheel maker) and there should be no reason to run more than 2 drivers unless it is required for big boost.
I just put on the Doo extros and maybe I'm just new to them but they drive both intro and extro, and i know that whal charges more for the intro/extro drive but the doos, already have it and they are $55/ea. Nice qualty to.
doo ones in 8 tooth arent correct pitch.they do make them in 9 and 10 though.
yamaha extroverts only run thru track window....unlike the aftermarket ones and doo that run thru window and on track drive knobs.
motodave289 said:
Did ski-doo use 8 tooth all I found on fich were 10 tooth.
Just did 9t 2.52p doo extros on a friends poo. I'll check with him but I'm pretty sure they were for a 04 Summit 800. $49.95 each and they worked real well. Nice and true and double outside cogs as well as the extro drive cogs. I don't think any of doos rev sleds came with 8t drivers, most with 9 or 10 in 2.52 pitch.
the do drivers are a way better deal imo, here are the part numbers, bought a set for my vmax 800
9 tooth #504152503
10 tooth #504152502
DO NOT use the 8t part # they are for 3" drive pitch.the other #'s are fine.doo doesnt make a 2.52" pitch 8t anti-driver.trust me i learned the hard way by trusting what someone posted on the 4stroke side about the part # for 8t.
