viperino
i didnt blow shop air through them but i was able to blow through them with a small can of compressed air and could see daylight through what appeared to be a very symmetrical clean hole. The holes in all three pilots also all appeared identical in size which led me to believe that they were completely clear.
i tried to run a small pin through the hole but it wouldnt fit. its diameter was only slightly larger that of a plastic garbage bag twist tie wire. I assumed that the pin was just a little too big. Or is it that the hole is still partially blocked?
could be blocked some still, dunno.....
viperino
I figured out that once i let the sled properly warm up, it runs like a champ, no low end bog at all. Just 'need a little patience' is all. Thanks again for the help.
Well yes,,a liquid cool sled needs warm up, i do a good 5-8mins wile i get
dressed.
dressed.
