Rear cooler questions SxR vs. SRX
Sxr700Bandit
Triple Piped 700 Triple
S.E. Michigan
Are they the same or are they different? I see different part numbers. I'm asking because my sled is triple piped and has motor mods, and I don't want to overheat. T
they are different the srx cooler has bigger tubes where you slide the hoses on. so you would need to make adapters so your hose will fit.. physically it should bolt up to your tunnel.bleedre will be different too,need to re drill for it.
what kinda mods? a sxr,vmax cooler does a good job..
srx,viper
sx,vmax
srx/viper rear cooler is 3times the surface area, way better cooling. if your getting a srx/viper cooler and installing it on a sx, get the srx/viper rear hoses, then you can spacer down to your running board heat exchangers.
It has triple pipes and a peak head. I'm just trying to be cautious, so I don't get stranded and have to walk/tow it out of the woods. Shoot if someone had both coolers I could use the tubes from the sxr and the cooler from the srx/viper and fab it for my application.
srx,viper
sx,vmax
