sledman1
I hit a log end-on that was hidden under the snow and had to get two new control rods. i didn't notice utill I had taken the old upper control rod out and then saw the new one that there is a slight angle to it. Which way does the bend go when installinng the upper rod.Should it lean towards the back of the machine or angle toward the front.Thanks,Rodney
Front suspension? If it is then yes the angle goes back... now I presume the angle you are talking about refers to where the eyelet on the trailing arm end ist at an angle. correct?
sledman1
I mean the angle of the rod where it mounts in at the bulhead
