suspension clicking on 2000 sx700r
OnDaTrail
Orange County, NY
I'm getting a steady clicking that seems to be coming from my track or at least it varies with the speed of the track. I can't see anyplace that the track is catching and I've made sure there is no ice etc. Is there a bearing or something else that goes on these that would make that sound, it feels like it's on the left side.
I had this on my 98 500 V-Max and it was a flat spot on the drive belt. Swap it out with a good one to rule the belt out.
things that i have found
fuel pump bracket catching stud
studd not tightend down enough inside the track and clicks on rear sissor
new slides not having the front or back tappered down
screw for slides losend up and catching clips
link hanging out of chain
bad belt
track clips bent
heat exchanger guards loose
stud partially tore out but only enough to touch, not enough to tear the heat exchanger.
anyone got any others?
