Okay, I just picked up a 2001 700SXR (2,000 miles) and while I've only put on about 5 miles, I notice that it has a slight bog when I hammer the throttle from a dead stop. It idles fine and midrange throttle response seems good. I discovered when searching that it was a common problem with the 600/700 SX's and SXR's. Is it a fuel problem? It's bone stock with an aftermarket can on it. The previous owner told me he just cleaned the carbs, but I'll take them off and clean them to be sure the pilots are clean. If the pilots don't fix it, what are the ideal fuel settings for a 700sxr (how many turns out)? Thanks
