Roost 'Er
^^ edited my post on ya daman, any idea what size id need?
why cant you take off the secondary clutch? simply grab a hold of it with one hand and take out the bolt with the other hand, if you have a impact gun you wont even need to hold it. you guys make it hard on yourselves
simply remove the clutch then drill out 3 rivets and the whole assembly will come out and you can work on it on the workbench instead of trying to stand on your head.
Puller?Roost 'Er said:^^ edited my post on ya daman, any idea what size id need?
Roost 'Er
mrviper700 said:why cant you take off the secondary clutch? simply grab a hold of it with one hand and take out the bolt with the other hand, if you have a impact gun you wont even need to hold it. you guys make it hard on yourselves![]()
I tried that it was pretty hard, also puit a belt around the shaft and tried to hold it couldnt get it..... got a puller from a store but they only had a front end type puller which didnt work worth shit, gonna grab a new dremel blade and cut the rivets or the actual bearing today
thanks for your help guys...
yam_apex91469
bearing is junk anyway - on mine I used an air hammer from the tunnel side and it popped right off
