02ViperMtn
check for fuel line crack on center carb. pressurize the hose in water to check for leaks. If a hose is bent the right way the crack will open up and allow a lot of air can get in. It has got to be due to a lot of air relative to the amount of fuel.
blueracer
hey did you guys happen to notice that this thread was from 2007???
02ViperMtn
damnit, i hate it when that happens! I wish people would post back what they conclude at the end of an issue
motodave289
Didn't post a conclusion because still not 100% sure what was the cause. Put it back together and installed a new updated fuel pump with out vent. Have put 5058 miles since the burn down with out any problem.
02ViperMtn
good to hear its working for ya.
600srxman
check your pulse line i just did the samething and my pulse line to my fuel pump had a same crack in it ( still factory lines to )
