installing extrovert drivers on a 98 SRX
MSRXRider
Spokane Wa.
So I finally got around to installing the anti-ratchet drivers on my SRX. Problem is how far do the drivers go from each end of the axle? Somebody has to know other then the Yamaha shop. Thanks
2 1/2" from clutch side end of shaft to outside of driver shaft.
5 5/16 from splined end to outside of driver shaft.
you'll want 9" center from center to center of driver teeth.hope that helps u.
Well I must have them all messed up. Does it matter how they go on the shaft? Do the teeth that go inside the track face out or in?
i dont understand what your saying.the drivers should have ( teeth) on both sides and around the diameter of sprocket also.there are timing mark arrows on sprockets that you need to have lined up.i guess i should asked what brand you have.
This is what I'm working with. I think I put them on back words. Arrows are lined up. the drivers are cycle works extroverts
I think you need to run your stock or same size external driver.
I just installed some Wahl extroverts, they have the drive cogs on both sides.
I got my Wahls from Hartman. I think they were about 150.
Someone here may have a better price.
These are the same ones that on my 99 Mtn Max. I have no trouble with them. Besides the used track I bought the inner cogs that the stock drives run on are tore up so I have to go with anti ratchets.
